Transeo Crepusculum
- TrollinSmurf
Re: Transeo Crepusculum
needs to strip those chars off the end of the textblocks smurf for that realm... that sounds like a conversion issue
- TrollinSmurf
no, go into NMR, under tools>textblocks>strip characters off of the end
copy whatever the characters that show up in the monster name and paste it into NMR to have it strip those off, click ok, compile update file, run recovery, DONE
- TrollinSmurf
NP
been a long time smurf
I keep the vent server open if people have questions on somethin and want to pick other people's brains@ mudvoice.servegame.com
also, if a BBS wants a private voice room, they can have it if they just let me know
- TrollinSmurf
excellent thanks...and yes it has...probably would have been back sooner but I lost everything and just did not have the motivation to try and put it together again
- TrollinSmurf
hopefully fixed the funky !$3 monster error, added portal room. In order to use portals must get a token from are portal goes to first. This means you have to get to the area once first under your own power and buy a free token while you are there. After that you can take the portal.
I might suggest putting up a global chat for your muti-mud, and some other globals would be cool too
if you need the progs, i can hook you up
