Nightmare Redux (NMR) Download Links
Re: Nightmare Redux (NMR) Download Links
New Release - v1.8 (05/09/2016)
-NEW: Monster attack simulator and Average/Max round calculator
-NEW: Setting to auto sort editors with lists in reverse order (highest record numbers first)
-NEW: Added "Find First" and "Find Last" room on map buttons to room editor
-UP: Changed drop down spell editor's "Type of Resist" to what I believe they actually mean
-UP: Added logging of the second universal modifier's only if option when chosen
-FIX: Universal modifier reported that it would set the directive to "0" when setting something to "= ##" (only the message was wrong, not the action)
-MME Export Updates (for future MME enhancements):
-UP: Added spell resist type (if the spell is completely resistible)
-UP: Added attack names field (will show attack names on monster details and in simulator)
-UP: Added average monster damage and true attack percentages (unique, calculated fields for MME)
-UP: Added room 1/238 to default list of excluded rooms
-UP: hidden exits with a 0 in para1 will no longer be considered an exit
-UP: Additional references now shown for some items and spells
-FIX: Fix for MME export erroring out when having a large number of database records
http://www.mudinfo.net/viewtopic.php?f= ... 3683#p3682
v1.8.1 (5/20/2016)
-UP: increased length of monster summon field on MME export (more accurate LAIR counts in new MME)
-UP: adjustments to monster attack sim for accuracy
-FIX: area attack durations spells being ignored by monster attack sim
v1.8.1 (5/20/2016)
Nice thanks for another update. Last room in a map is my favorite feature of all times, it makes my life so easier.
I haven't added this update to my NMR. How do I import/install this over the 1.6.1 version I have without disrupting current settings/users etc?
Just run the installer. It won't erase any settings.Storm wrote:I haven't added this update to my NMR. How do I import/install this over the 1.6.1 version I have without disrupting current settings/users etc?
- Necrosaro420
he was trying to import mudrev had some issues i had it so got it to him but had same issue so installed siliconrev on a vm and exported for him worked great
I downloaded 1.8.1 but it says it isnt compatible with majormud1.11n which I am running. Do you have a version that would work? thanks
