Are you the only one in the game when this happens?
When you say clean install/no edits, do you mean you re-installed the entire game or do you mean you used the .Z file to replace the map database?
Have you installed the game before, with the same install files you're using now, and had a smooth running bbs without errors? Or is this the first time with your own board using those install files?
orc mansion crash
Re: orc mansion crash
Just out of curiosity, are you a bard, or was there a bard online when these crashes occurred?
what version of mud?
you try not logging in from console and using megamud?
what version of winblows?
maybe try and find another zip of mud 1.11p
unless you were able to fix problem
it saying 0 users means it didnt take your key, the crash entering orc mansion (mod 1) with an invalid key and a most likely empty wccaddon.sys the game errors when you enter mod 1, i bet the same thing happens if you go through the western door. if you are sure your key is good, then the solution is to enter the addon codes into mud, or just edit the file manually, its wccaddon.sys the format is simple mod#:modkey, so the file should be:
1:YOURMOD1KEYHERE
2:YOURMOD2KEYHERE
etc. down to 9
1:YOURMOD1KEYHERE
2:YOURMOD2KEYHERE
etc. down to 9
