Spellbook Limit
Rothchild
Spellbook Limit
Post by Rothchild » Wed Mar 20, 2019 2:21 pm
Are we stuck with the 99 spell limit in the player's spellbook, or is there a dll edit that can change it? Is there any way to forget spells, besides editing the user?
Kyau
Re: Spellbook Limit
Post by Kyau » Wed Mar 20, 2019 3:37 pm
Without hex editing, yes you are limited to 99.
I assume changing this would be quite the task, unless you repurposed unused slots in the character sheets... but even then you are limited.
Re: Spellbook Limit
Post by BearFather » Wed Mar 20, 2019 10:10 pm
The way I deal with this is give items that give temp spells, that way they don't have them in their permanent spell book and can have more depending on the item equip'd
Kyau
Re: Spellbook Limit
Post by Kyau » Thu Mar 21, 2019 1:48 am
Good call Bear, I forgot I do this as well.
Dizasta
Re: Spellbook Limit
Post by Dizasta » Tue Oct 15, 2019 12:35 am
So your saying item's spells get put into the player's spell book? Also the purge command removes any spell from the spell book. Ex. purge spell. Fair warning though this works on kai too and once you purge a KAI power you'll never be able to get it back.
Re: Spellbook Limit
Post by BearFather » Tue Oct 15, 2019 9:58 am
If you have an item with "givetempsp" ability it will add the spell listed to the players spell book while the item is worn.
Dizasta
Re: Spellbook Limit
Post by Dizasta » Thu Dec 05, 2019 4:10 pm
Was there any items that used this ability ever in Majormud?
Re: Spellbook Limit
Post by BearFather » Thu Dec 05, 2019 9:54 pm
I don't think so, I can't think of any.
