GosLink3
Posted: Sun Aug 26, 2018 3:13 pm
I have rewrote GosLink and decided to create a new post for it. Mainly cause it works in a whole new way so none of the old configs will work in the new system, except messages.cfg. Now for the sales pitch...
GosLink is a java bot that will link upto 3 realms gossips and telepaths. It also has a admin and webchat built in too. It all sounds too good to be true. Well today is the day to blow your mind!
This is the 3rd version of Goslink, It's new and improved with even more zest!.
Admin bot commands: @abils, @good, @neutral, @evil, @retrain, @where, @repeat, @home, @who, @tele,@notify
@abils:
Display the player's their current abils. I use https://quest-ware.webs.com/queststeps.htm to dcypher.
@good,@neutral,@evil:
Will set player's alignment to that version.
@retrain:
Will retrain player's stat's so next login they have to reassign stats and end up in town.
@where:
Will tell player's room and map room numbers, and if their is a boss thier regen info.
@repeat:
Will send the @command sent back to the player.
@home room# map#:
Will return boss info on room specified.
@who:
Will list players in all the realms.
@who <realm>:
Will list players in the specified realm.
@tele <realm> <player> <msg>:
To send a telepath to a player in another realm.
@tele @help:
Will give you help on the command.
@notify <msg>
Will save the message for the admin to retrieve later.
@notify ran by admin will display notify messages sent to the bot.
@reg (Will not work if webbot=false)
This is used to register an account or update the password for GosLinkChat.
@reg <password>
Will create a web chat account, and produce a hash to login.
@reg update <old password> <new password>
Will update stored password with new one.
@reg hash <password>
Will resend the users hash.
@mail <player>@<realm> msg
Will send a mail to player in the realm selected.
@mail help
Will display the help message
@checkmail
Will check for new mail sent to you.
Admin Commands: !reload, @notify
@notify:
Will display messages sent to the bot.
!reload:
Will reload the give settings
!reload deny:
Will reload that realms deny file.
!reload messages:
Will reload the messages.cfg file.
!reload properties:
Will reload the config.properties file. This is not recommended if you change too many things, just restart.
!newusers:
This will show you users in the noobclass field. It will display creation date and module the user is in.
!hashlist
Will display of all hashes currently created.
@abils:
@retrain:
@where:
@repeat:
@home room# map#:
@who:
@who <realm>:
@tele @help:
@notify <msg>
@reg <password>
@mail help
@checkmail
@notify:
!reload:
!reload deny:
!reload messages:
!reload properties:
!newusers:
!hashlist
