Removing Good/Neutral/Evil only flags in NMR?
Necrosaro420
Post by Necrosaro420 » Thu Jul 12, 2018 5:35 pm
Is there a way to remove the alignment requirements for items in NMR instead of doing each one individually? Unless I missed it, did not see that option anywhere?
Re: Removing Good/Neutral/Evil only flags in NMR?
Post by syntax » Thu Jul 12, 2018 8:08 pm
I don't have NMR installed on anything right now, but can't that be done through the mass change tool?
Ravyn
Post by Ravyn » Thu Jul 12, 2018 11:15 pm
I don't believe so. I have it pulled up and closest thing is "universal modifier" then choose "items" then "change ability" then you can change the value by adding, subtracting, setting value, dividing etc. since the ability works with any value (NeutralOnly 0 is same as Neutralonly 100) i don't think itll work. exceptions may be changing EvilOnly from a higher value to 0, so you can use it as a lesser evil person?
Post by syntax » Thu Jul 12, 2018 11:16 pm
remove ability isn't an option??
Necrosaro420
Post by Necrosaro420 » Fri Jul 13, 2018 1:19 am
Nope, not seeing remove ability in the universal modifier section.
Post by Bloodrock » Sun Jul 15, 2018 7:30 pm
i'd think use change ability would do what you want choose the abil and modifier would be = 0 would prob have to do it for each alignment
