BTRIEVE OPEN ERROR 86 ON WCCACMS2.DAT
Posted: Tue Aug 08, 2017 5:24 pm
Has anyone seen this error before and have a solution?
It is a brand new WGS 3.20 install, and a fresh install of MajorMUD v1.11p.
I've followed the steps from this forums on setting up a new system, but I can't seem to get past this.
I get this error as soon as I try and start the server. It starts, looks like it's about to give the 'ready' status, but then errors out.
I've made sure the file is present in the \WGSERV\ directory, and I've tried copying the .vir over the .dat but that didn't work.
I've tried running the offline utility for MajorMUD to restore the database files, and I've also tried the WGS file integrity check.
The BTRIEVE error code list on this site lists ERROR 86 as a full file? But I'm not sure what that means. How could it be full if it is a new file?
Any help would be appreciated, thanks!
This is on Win764 if that helps at all.
