megamud key
kps1662
megamud key
Post by kps1662 »
I'v purchased megamud three times over the years and would love to play majormud again but not gonna shell out any more money could someone help me out with a registration code? megamud id EBEB-3422-AFAF
thanks
Re: megamud key
here is a keygen
Keygen1.zip
(13.88 KiB) Downloaded 1628 times
Sodium
Re: megamud key
Post by Sodium »
What the hell. I used the keygen and plugged in the USER ID and my name and the keygen created something but it was so fast and it also closed out the program so I've no idear what to do or what to plug in to register megamud. My goodness I loathe PC's.
Re: megamud key
If you look it generated a text file like megamudkeys.txt or something like that. That has a list of keys choose one.
Sodium
Re: megamud key
Post by Sodium »
BearFather wrote: Sun Nov 26, 2023 9:09 am If you look it generated a text file like megamudkeys.txt or something like that. That has a list of keys choose one.
I can't locate where the txt file that's generated is located on my PC. For context I ran the keygen from the downloads folder and I've tried searching the entire C drive for a file named key or keygen and came up empty apart from the keygen.zip file. This is beyond frustrating.
Re: megamud key
It should be in the same location the exe runs from. Now if you run the exe from inside the zip it won't be able to run and write the file in the same location. So make sure you extract it first.
