Level 100+ Training Rainbow Cave
Moderator: BearFather
Webslinger
Post by Webslinger »
Just thought I'd post up the stats before and after I trained so you can see them for yourself. Note in the second stat post, my hp was 1798 (where it should've been), but then after the forward slash it showed 1556 (1798/1556).
Name: Webslinger Thwip                 Lives/CP:      8/2085
Race: Dwarf       Exp: 66873579177     Perception:    128
Class: Paladin    Level: 111           Stealth:         0
Hits:  1798/1798  Armour Class: 124/77 Thievery:        0
Mana: * 263/263   Spellcasting: 321    Traps:           0
                                       Picklocks:       0
Strength: *130    Agility: 100         Tracking:        0
Intellect: 100    Health:  140         Martial Arts:   83
Willpower: 140    Charm:   85          MagicRes:      185
Name: Webslinger Thwip                 Lives/CP:      9/2150
Class: Paladin    Level: 112           Stealth:         0
Hits:  1798/1556  Armour Class: 124/77 Thievery:        0
Mana: * 263/265   Spellcasting: 323    Traps:           0
                                       Picklocks:       0
Re: Level 100+ Training Rainbow Cave
 tags are your friend :)
Webslinger
They are now :oops:
virucizer
Post by virucizer »
This happens all the time to high levels on mudrev too. There must be some hp variable that is only one byte, because you always seem to lose just under 255 hp.
I've wondered if mmud just stores HP as the number of hp above the minimum for your level/class, or something. Then when they calculate your max hp, they take (minimum for your class * your level) and add the HP variable. That might have allowed them to change the HP ranges on classes without missing existing characters.
Yeah came to find out there was a spell on him that altered his HP's when he went to train. And it didn't like that, and nothing I can do will give it back to him.
