Darkwood BBS Release Notes
Moderator: DarkwoodBBS
1.5.0 2020-09-18
Assorted bug fixes / minor enhancements
- Fix more rooms west of dismagi that randomly punted you to DTH for exit/entering
- Fix a few more monsters who dropped items that didn't stack/group in the room, but should.
- Update mant and quik to counter missing slow spells that are countered by sped. (Wizard sfog still has no counter)
- Fix ice storm scroll from ice sorc
- give 9th quest rewards the usage abilities implied by the textblocks that give them to players
- Fix Maestro and Wardancer in Lissom quest
1.4.1 2020-07-16
Beef up medal of endurance a bit as start of minor upgrades to WHs, 5th quest weapon viability
- Update all 5th quest weapons from Magic 5 to Magic 7.
- Minor improvement to medal of endurance
1.4.0 2020-07-15
- Fix temple area in southwest slums so that it is affected by cleanup
- Fix Crystal forest so cleanup happens there
- Delete 19781 rooms, accounting for over one third of the rooms database size
- add eyes of the creator to quest pawn shop
- Fix some shop names so their names are not misleading about where they are
1.3.2 2020-07-05
- Add some regen to Gleaming Caves so it might get occasional attention
- Reduce drop rates for stackable, no-slot items
- Introduce shops to sell unneeded 4th quest cloaks
- Introduce shops to sell unneeded 5th quest items
1.3.1 2020-06-23
Armor progression tweaks. Generally higher level armors should be better. Drops and customs should be better than purchases. Rare/challenging items can be better than higher level counterparts.
- Swap Dragonforge Scalemail and shimmering scalemail tunic AC/DR
- Reduce runed silver leggings AC to try to balance out the crazy +maxdamage.
- Improve scarlet doublet
- Update caster leather armor progression to be better than earlier models (for example, level 120 storebought gear was worse than 90)
- Added Darkwood Shield so Rgr isn't stuck with the same shield from level 40
- A few smaller changes
1.3.0.3 2020-06-22
Sell spot for undroppable junk
- Added Death Shroud to junkyard shop
1.3.0.2 2020-06-18
Monster spawn fixes
- Fix problem preventing high druid from spawning when time was up
- Fix problem preventing giant pulsating cocoon from spawning when time was up
1.3.0.1 2020-06-14
Tweaks to crypt
- Change exit south of mummy room to be normal instead of door
- Allow up to lvl 20 in crypt
1.3.0 2020-06-11
Crypt Quest
- Reintroduce crypt quest for classes #1-15
- Handle class changes in 1-15 (Cleric -> Necrolyte, Warlock -> Arborean)
- Create crypt quest for classes 16-25
- Substantial markup for level 10 quest items the easy way
- Training in crypt is optional - adventurer's guild still does 1-99
- Fix some problems with shimmering chainmail. It should now be more desirable than level 45 and less than level 75 chain sets.
- Fix Dragonscale Belt deleting at cleanup even though it lacked Delete@Cleanup flag.
1.2.4.2 2020-06-05
- Some bosses/monsters drop items with numbered uses, so over time these fill up all the item/hidden item slots in neighboring rooms and can cause items to poof upon player death in a room.
- Litter control: potions and containers delete at cleanup.
- Litter control: ice wizard doesn't drop frost sceptre.
- Make greater pressure points better than pressure points.
- Revert edits that removed backstab capability of some quest weapons.
- Change all 50 quest weapons to 0 weight because there is no way to be rid of them. Most were already 0, but a few were missed.
1.2.4.1 2020-05-23
MudBot Upgrades
- Change !abil to translate ability #s to ability names
- add !config for info on realm setup
- add !mme for mme link
1.2.4 2020-05-22
Fix broken Mudrev abilities and related exploits. (Thanks Syntax for info on where to hex edit)
- Update Dhelvanen Quest to persist after offline recoveries
- Update Spectral Knight Quest to persist after offline recoveries. Previously repeatable for another EXP reward.
- Update Faerie Queen Quest to persist after offline recoveries
- Update Lissom Overlord reward to persist after offline recoveries. This bug would likely have allowed this to be completed repeatedly, for stacking backstab bonuses on unpatched boards.
1.2.3.2 03/19/16
old mudrev tweak
- Change Tunic of Trickery from Leather to Chain and adjust AC accordingly
1.2.3.1 03/16/16
old mudrev hotfix
- Add Gypsy textblock for 5th good reward
1.2.3 03/08/16
Small tweaks after go-live
- Add Gypsys to chain shields
- Add Rgr to silk shields
- Place Sunburst Wrist-guard in a shop
- Adjust some drops that should have been 10% down from 100%
1.2.2 02/20/16
Finish Ninth Alignment Quest
- story for all aligns
- single use items to help with the big bads during the quest
- new reward items
1.2.1 02/19/16
Ninth Alignment Quest, contd
- Mechanics of 9th Evil and Good (no story)
- begin to write story text
1.2.0 02/18/16
- Created conversation mobs
- Mechanics of 9th Neutral (no story)
1.1.1 02/16/16
Fix stupid level restricts on exits
- from 20 more rooms
1.1.0 02/14/16
Prep for open
- modify help files for racial stat updates
- modify temple noise to point to mudinfo page
- modify help files (release, etc) to point to mudinfo page
- move from ansi 'on' to 'Ask' to hopefully combat situations where megamud overrides the 'on' setting.
1.0.4 02/10/16
Eighth Alignment Quest, wrap-up
- clean up story text a bit
- write reward item descriptions
- tweak quest help file
1.0.3 02/09/16
Eighth Alignment Quest, contd
- story text for 8th Neutral quest
1.0.2 02/08/16
- story text for 8th Evil quest
1.0.1.1 02/07/16
Neut/Evil quest fixes
- Fix textblock overflows
1.0.1 02/07/16
- Mechanics (Textblocks, spells, items, monsters) for 8th neutral and evil (no story text)
1.0.0.1 02/06/16
Good quest fixes
- Change recall destination from TS to Portal Room
1.0.0 02/06/16
- Implement 8th alignment quest for Good
- add classOK on some armor sets for consistency with the rest of the progression
- remove 5th quest flags from Enigma Master
- remove missing/broken spells from a few mudrev mobs
0.3.3 02/03/16
Spell stacking usability. (Please let me know if you find other timed duration spell message conflicts)
- resolve spell message conflicts (tige/jagr,smit/gsmi,mshi/shld)
- remove blade of antimagi from shop
0.3.2 02/02/16
More variety for WHs, give Bardly magic a little love
- ensure all markup rates are above 100%
- charm increase across all races
- beef up obsidian scale
- add/tweak high end witchy weapon options
- tweak some bard spell durations
- add final staff for maestro to match the other M3s
- tweak duration of a few item uses
0.3.1 02/01/16
Shop fixes/upgrades, tweak some spells
- add missing classes to Superstealth quest
- remove mudrev quest items from being for sale at shops (dragonscale belt, firestone pendant, onyx bracelet, etc). Now they are sell-to-the-shop only.
- increase shop stock from 3 to 99
- remove bogus shops from non-existent towns, etc (for clearer MME browsing)
- reduce vicar healing rain level to 120 to equalize distance between priest3 room heals
- neuter ether death so players aren't wiped out if they happen to walk to jorah while room attacking
0.3.0 02/01/16
Fix remaining mudrev exploits and bugs. Slight increase of regen and drop rates. Create/place some items to fill gaps in existing progressions.
- remove cheater items from shops (god blade, holder item, etc)
- remove archer from numerous non-arrow weapons
- any drop on a monster with timed regen is now at least 10%
- increase drop rate on low-level monsters with timed regen (now often greater than 10%)
- reduce any regen times over a day to 24 hours or less
- reduce regen time of many quest-related bosses even if they were already <24 hours
- create arlysian arrow
- beef up dismagi rings
- placed black wyvernhide armor (only tunic was in game)
0.2.4 01/31/16
Fix remaining problems in level 185 gear
- Make Ethereal Silk Robes available for custom
- Review all other level 185 customs
0.2.3 01/31/16
Implement Epic's upgrades, cont
- Merged EpicRev's textblocks
0.2.2 01/30/16
- Merged EpicRev's spell dats
- Merged EpicRev's monster dats
- Merged EpicRev's race dats
- Merged EpicRev's shops dats
- Merged EpicRev's room dats
0.2.1 01/29/16
- Merged EpicRev's class dats
- Merged EpicRev's item dats
0.2.0 01/29/16
Implement Mudrev
- Loaded Mudrev dats based on Silicon's edits dated 9/25/2010
0.1.0 01/29/16
Initial launch
- Deployed stock realm
1.4.1 2020-07-16
1.4.0 2020-07-15
1.3.2 2020-07-05
1.3.1 2020-06-23
1.3.0.3 2020-06-22
1.3.0.2 2020-06-18
Monster spawn fixes
1.3.0.1 2020-06-14
Tweaks to crypt
1.3.0 2020-06-11
Crypt Quest
1.2.4.2 2020-06-05
1.2.4.1 2020-05-23
MudBot Upgrades
1.2.4 2020-05-22
1.2.3.2 03/19/16
old mudrev tweak
1.2.3.1 03/16/16
old mudrev hotfix
1.2.3 03/08/16
1.2.2 02/20/16
- new reward items
1.2.1 02/19/16
1.2.0 02/18/16
1.1.1 02/16/16
1.1.0 02/14/16
Prep for open
1.0.4 02/10/16
1.0.3 02/09/16
1.0.2 02/08/16
1.0.1.1 02/07/16
1.0.1 02/07/16
1.0.0.1 02/06/16
Good quest fixes
1.0.0 02/06/16
0.3.3 02/03/16
0.3.2 02/02/16
0.3.1 02/01/16
0.3.0 02/01/16
0.2.4 01/31/16
0.2.3 01/31/16
0.2.2 01/30/16
0.2.1 01/29/16
0.2.0 01/29/16
Implement Mudrev
0.1.0 01/29/16
Initial launch
telnet://darkwood.ddns.net -- Mudrev with fixed and enhanced content, 25 level PVP
Information: http://www.mudinfo.net/viewforum.php?f=55
Re: Darkwood BBS Release Notes
1.2.0 02/18/16
1.2.1 02/19/16
1.2.2 02/20/16
- new reward items
- new reward items
1.2.3 03/08/16
1.2.4 2020-05-22
1.2.3.2 03/19/16
old mudrev tweak
1.2.3.1 03/16/16
old mudrev hotfix
1.2.3.2 03/19/16
old mudrev tweak
1.2.3.1 03/16/16
old mudrev hotfix
1.2.4.2 2020-06-05
1.3.0 2020-06-11
Crypt Quest
The MME is updated.
https://drive.google.com/file/d/0B67qCx ... EB02A-Z-TQ
Crypt Quest
The MME is updated.
Darkwood BBS Release Notes - 1.3.1
1.3.1 2020-06-23
1.3.0.3 2020-06-22
1.3.0.2 2020-06-18
Monster spawn fixes
1.3.0.1 2020-06-14
Tweaks to crypt
The existing MME link is updated.
1.3.0.3 2020-06-22
1.3.0.2 2020-06-18
Monster spawn fixes
1.3.0.1 2020-06-14
Tweaks to crypt
1.4.0 2020-07-15
1.3.2 2020-07-05
1.3.2 2020-07-05
