Page 2 of 4
Re: Gos Link
Posted: Tue Mar 22, 2016 11:50 am
Thursday is my next day off, would love to sit down and figure out what's going on at cleanup that stops it from logging in. What time is your cleanup? I will also work on a timed broadcast message.
Re: Gos Link
Posted: Tue Mar 22, 2016 11:53 am
BearFather wrote:What time is your cleanup?
3am EDT. I could always change it. Only two of us messing around right now.
Re: Gos Link
Posted: Wed Mar 23, 2016 3:02 am
Well I got thursday and friday off so we can sit down and look at when ever you got time. Also what is your cleanup time set too?
Re: Gos Link
Posted: Wed Mar 23, 2016 7:35 am
BearFather wrote:Also what is your cleanup time set too?
syntax wrote:BearFather wrote:What time is your cleanup?
p.s. It reconnected fine last night. Only one "SGA" error in log.
Re: Gos Link
Posted: Wed Mar 23, 2016 2:16 pm
It knew I was coming to look at it's bits and it now straightened up it's act.
Let me know if it runs ok tonight after cleanup.
Re: Gos Link
Posted: Fri Mar 25, 2016 4:43 am
Updated to version 5.1
Added the ability to change the entrance message.
Added the ability to spam up to 6 messages, after a certain amount of time.
Added a setting to disable ansi with "=a" after login.
Added messages.cfg-default, it's for setting the messages.
Re: Gos Link
Posted: Fri Mar 25, 2016 5:21 am
Updated to 5.2
Added the option to add a timestamp to the window. (set timestamp=true)
Cleaned up some code.
Re: Gos Link
Posted: Fri Mar 25, 2016 10:27 am
Awesome man. I have it installed now. Will let you know how it works out.
p.s. He's been reconnecting at cleanup fine since I posted. <shrug>
Re: Gos Link
Posted: Sun Mar 27, 2016 11:22 pm
syntax wrote:Awesome man. I have it installed now. Will let you know how it works out.
This has been working great. Made use of the rotating messages too. Thanks for the good work.
Two things--
a) can you make it so you can resize the window and have the actual log area expand with it? (as it is it expands the window where I can see a debug button but everything else stays).
b) add a flag to disable sending people tells when they enter the realm?
Re: Gos Link
Posted: Mon Mar 28, 2016 9:29 am
The resize I agree has always bugged me but never did anything about it, and it suppose to stop bugging them after 5 login's. Prefer just never do it?
