Gos Link
Posted: Fri May 02, 2014 5:22 am
This version is no longer maintained. Please check here: http://www.mudinfo.net/viewtopic.php?f=47&t=2454
Do you have two realms on you board? Have you ever wanted to link their gossips? Do you and a friend both have a realm, and would like to link their Gossips? Well I got an app for you.
Ok I'm done with the salesman bull now.
Goslink is a java program that links up to 3 chat's, and it can act as a sysop bot. It will work in Linux and Windows. Should work on a mac too, but not tested. It will also see cleanup's and reconnect after a set period of time(your choice). And even has a web chat port to connect a web page up to get live chat on the web. Now has the ability to link to gossip global server.
Current sysbot commands:
@help
@abils - returns players currently abilities set(quest flags)
@good -sets player good
@neutral -sets player neutral
@evil -sets player evil
@retrain - retrains players stats
@home room# map# - gives status of boss in that room.
@where - tells you your current room number, and boss info if there is one.
@repeat - will repeat the megamud command back.
@notify - Allows players to send sysop messages to be read later.
Also will send a player info when they enter the realm.
Github:
https://github.com/BearFather/GosLink2
@help
Github:
