Shadowmere Converted
Author: Southerncross (Email: deathcored29 at yahoo)
Created: 6/6/2009
Base Mud Version: v1.11p w/1.02x conversion
Description--
This is Shadowmere Converted and debuged. It now rest on map 1 from 3651 to 5530. Do no install it if you have edits in that area. It will overwrite them. I did not supply any mobs or eq with it. This was a debug and coverion of map 18 onto a new map. You will have to set up the shops and contraol rooms and add your own mobs. The index is already set within range.
Shadowmere_v1.0.zip
(181.08 KiB) Downloaded 519 times
