Created: 03/09/2011
Base Mud Version: v1.11p
Description--
In most stock realms, the "Hard Trainer" is simply never used. This mod alters the "Shakabuku" room of the easy trainer, allowing you to train easily and also still do the hard trainer path. The hard trainer has also been altered to allow you unfettered access after level 68. Bosses have been rescaled in experience value to support high-level boss runs and limited scripting now in the Fortress. The hard trainer path is no longer limited in how many times per day it can be done.
This mod works particularly well with Demosthenes' Recall Mod, and is designed for a stock or similar realm.
As is, the Hard Trainer path is altered from its stock path. The class-limited section access has been removed, and I will possibly revamp those sections and add them in at a later time. The new section order is:
Fortress, Hedge Maze, Heavenly Sky/Burning Valley, Grand Hallway
Ancient Fortress Mod - v1.0 by F. Hostile 2/19/2011
Changes:
Name Nahr (1004)
Experience 1,500,000
Name Nahr (1010)
Experience 8,000,000
Name Nahr (1011)
Name Majestic Dragon (1013)
Experience 10,000,000
Regen Time 4 hour(s)
Name Golden Phoenix (1014)
Name Demon Lord (1015)
Name Great Hydra (1016)
Experience 7,000,000
Name Azrandimon (1030)
Experience 3,000,000
Name Lorzina (1032)
Experience 2,000,000
Name ancient sand dragon (1034)
Experience 500,000
Name fallen angel (1035)
Experience 500,000
Name aged earth dragon (1036)
Experience 1,000,000
Name Dao Lord (1037)
Experience 500,000
Name great green dragon (1038)
Experience 2,500,000
Name giant roc (1039)
Name Darken Beast Lord (1040)
Name Lord of the Hunt (1041)
Name silver warrior (1044)
Experience 28,000
Name marble archer (1045)
Experience 36,000
Name golden mist (1046)
Experience 26,000
Name spiked juggernaut (1048)
Experience 36,000
Name Devil Fiend (1049)
Name Demoness (1050)
Name fanged demon (1051)
Experience 27,000
Name red sphere (1080)
Name blue sphere (1081)
Name green sphere (1082)
Name yellow sphere (1083)
Name Nahr (1084)
Room 12/2368 (Shakabuku Room)
Room 17/2982 (Grand Hallway Entry)
Room 17/3009 (Vaulted Throne Room)
Room 17/3086 (Vaulted Chamber)
Room 17/3087 (Other Vaulted Throne Room)
Item Number: 1891, Name: great hydra statue, Type: Sign, Enc: 32000, Limit: 0
>> Abilities: Del@Maint, RoomVisible -- Not Getable, Destroys On Death
>> References: Room: Ancient Fortress (17/2980), Textblock 4120
Item Number: 1979, Name: stone wall letters
Textblock 4120: Great Hydra summon adjustment
Textblock 4211: Adjusts level checks
Textblock 4212: Adjusts level checks
Textblock 4244: Great Hydra Portal adjustment
Textblock 4285: Nahr's throne block adjustments, dummy abil added for later development
Textblock 4286: Nahr's room teleport/scatter
Textblock 4328: Shakabuku adjustments (Minlvl 67, doesn't flag)
Message 3399: Changed branding Message
Shop 181: Easy trainer changed, level 65-100
Shop 182: Training keys spawn every 5 minutes but cost 20% more
