Issue with Tasloi (hard loop) Megamud keeps stoping
I have been doing the tasloi hard loop with all the bosses and for some reason on that loop and that loop only my priest keeps shooting an @wait command and never issuing the @ok command and the only way to get it to go again is lowering the rest max 1% then it goes for a lil bit and does it again. Has anyone had this problem and if so do you know how to fix it?
Re: Issue with Tasloi (hard loop) Megamud keeps stoping
Usually this happens when it gets hit by a curse, but does not properly recognize the Ends With message for that curse. You may be able to resolve it by fixing the message/responses, by adding a st^M response to the ends with message, or by setting up an event to type st.
I have a event with st alrdy and it still doesnt help, I've tried almost everything I can think of and it still does it no matter what
This was happening to me until I changed the end message of the net from:Drizzt wrote:I have a event with st alrdy and it still doesnt help, I've tried almost everything I can think of and it still does it no matter what
"You work yourself free again."
To
"You work yourself free."
