MudRev realm resetting Nov 17th
BBS Advertisements. Post about your new/existing board.
cuckoorules
Post by cuckoorules »
Telnet address: bbs.bearfather.net
Option R from menu is the MudRev realm I am running (BearFather is kindly hosting it on his BBS, I am Mudop and Editor for the MudRev realm)
Max Chars per person: 2 online at any given time (for this realm), a third allowed once you reach level 70+
Max Level: 300
Death: -1000 (may change at reset)
Hangup penalty: none
Sys Commands: Sys Map is available to all players.
Portal system to all major towns, recall potions and spells/items in place of sys gotos.
Custom ganghouses in the realm with no way to break in. Uses a teleport spells so you can get there from any location similar to the recall spells/potions.
MME Dats and Custom Paths are available on bearfather.net in the Files section.
Bot available that can retrain, change alignment, tell you the last kill time/status of any boss (via room#) as well as what room you're currently in. It also shares gossips among the 3 realms of the BBS (on the auction channel, so easily blocked if you don't like chat much).
Tons of additional quests beyond those of stock.
cuckoorules
Re: MudRev realm resetting Nov 17th
Reset is complete.
