my bbs list (updated 11-24-2017)
Post by Bloodrock » Thu Mar 30, 2017 7:19 pm
if you know of a board not in list please let me know
Lostways BBS started in 1989
Realm 1 telnet address 216.108.229.159 port 5555
for mme file on mmud fb page realm1.zip or in bbs file library realm1.zip mme can also be found by typing /thesys mme for link to megasync
(realm 1 train to 450)(as many chars as you want)(cp stats raised)(no lims)(2x exp)
realm has ob fort mod lair mod fighter glasses mod glasses edited so all classes can wear lots of new gear and weapons 70 lockers to store items lockers
are located west of west wall and oak streets and south of khaz and new ganghouses lots of new areas paths and loops included in mme zip file
for paths and loops it is best to unzip to c:\megamud\chars\all folder gjr's sold in newhaven auto bot for @home and @alive for new bosses other
bot commands are: /thesys retrain life good neutral evil mme {hod auto heals} sysop of board is thesysop [anton pfeil]
Realms 2 and 3
telnet address 99.73.141.110 or lostwaysbbs.mooo.com or lostwaysbbs.crabdance.com
realm 2 slightly edited train to 100 4 chars (no lims) sashes mod lair mod and fighter glasses mod lockers above sil ts
mme is realm2.zip can type /thesys mme in realm for link
realm3 is same as realm1 but less things in it thou has some things realm 1 does not train to 400
Forever BBS
IP: 172.31.11.89 telnet: majormud.us 23 stock realm 4 chars per ip Sysop: R Suarez
Darkwood BBS
to be reset??
darkwood.ddns.net 69.245.253.45 (Based off Silicon, with Epic's Mudrev edits merged in, and additional content added).
pvp level 25 MME Data Available: https://drive.google.com/file/d/0B67qCx ... ef=2&pli=1
Utopia bbs
utopiabbs.com (2 chars)(stock slight edits sys map @home)(pvp 10 levels) bbs info at www.utopiabbs.com
Ignition BBS
18.221.141.17 lair mod spell mod 2x quest mod limited items sys map pvp 10 levels
shinra inc bbs
73.154.41.143 2 chars per ip default setting for pvp items are limited per default
brujah bbs
brujahbbs.ddns.net 2x exp 2 new races 2 new classes 3 chars per ip mudbot non-pvp
the original Mudbox BBS Pimptite
pimptite.com port 6969 and 23 (stock realm 3 chars) sysop:jeremy wilson
Oblivion BBS
mud.stylez.us Stock realm pvp no limited items 3 chars per ip
Black Wasteland BBS
blackwasteland.com 3 chars per ip pvp enabled no lvl mentioned death -40
Warlocks, Missionaries, and Gypsies all have Combat-3, and that Warlocks and Missionaries can now use all weapons.
Priests armor spells supply double their previous AC.
CodeRed BBS
coderedmud.servegame.com port 2323 (2 chars)(pvp but coop)(unique edits)
Mudbot commands/align change/retrain/etc (sys gotos) sysop is ravyn
Dreamline BBS
din.themajorbbs.com (pvp stock dupes allowed {be reasonable}) newly reset
Mudlite BBS
50.26.190.17 no lims sys go to, and map. could careless on dupes
Del's Place BBS
52.14.183.100 no edits, 2 characters max, gold jeweled rings upon request (at level 10).
Dado's Blade BBS (freshly reset)
dadosbladebbs.dyndns.org (3 chars per ip stock lightly edited pvp 10
lairmod newhaven monsters 3x except cave bear caveworm and slimebeast 2x exp
sys goto and map and mudbot sysop bizkit
Dungeons of Insanity BBS Realm 1
Dungeonsbbs.com Port 2323 4 chars allowed NO LIMS! Lair mod Spell mod
-=T-LORD=- is available for play in **DOORS**
Sash's and Fighter eyeglass mod (cloakroom) Double quest mod
150% monster exp doubled monster drops
LVL 10 Quest weapons are sold at Universal trainer whotrains 1-100 really cheap.
2nd quest heads, orc-heads and black diamonds are sold in General store.
LVL 50 quest weapons and spells sold now in Junkyard!
Free gold jeweled rings are sold and Meia (curio shop).
10 LVL PVP +20 to max stats Unlimited apparatus kills per day/once per char.
@home's @retrains @good, neutral, evil Jorah is now a disposable room.
Rope and grapple are loyal Sys gotos and Sys map Chars will be deleted after 30 days of not playing.
realm 2
2 chars max 10 lvl PVP 3 x Lims -30 death sys map spell mod (fixed) lair mod 2x exp +10 stats
BentoBox BBS
BentoBoxBBS.com
It contains 10 different copies of MajorMUD, all accessible from one BBS. Each copy of MMUD correlates
to one "Mod" of MMUD, starting with Mod 0 (Original 1.0 version of MMUD) and going all the way up to Mod 9.
It gives you a great opportunity to see how MMUD developed over the years, or even play on a particular
version of MMUD from your personal MMUD heyday.
2 chars per ip
(gave no info on how many chars per ip or pvp range as of yet anyways)
ClassicMUD - nothing fancy, just MUD the way your daddy played it!
bbs.ClassicMUD.com (port 2323)
ClassicMUD is a single character per player, per realm, board with two MajorMUD realms (PVP and NO PVP), T-LORD, and Blademaster. There is no playing Sysop, no sys powers or GJR, and sysop aid is not regularly given. The realms are almost entirely stock with the only notable exception being the removal of "bash" as attack options. Boss regen times have been reduced by half, items are not limited, and first-kill drops of items is not guaranteed.
- (PVP) enabled at +/- 9 levels with a 10% HP hang penalty and death at -30
- (NO PVP) is disabled with death at -100
***IMPORTANT*** You must verify your account(s) for the specific realm(s) you wish to play in before you can train beyond level 9. To verify you must be able to message or contact me from an established profile that clearly identifies you in order to ensure the single character per player, per realm, integrity of the board. Messaging me directly on Facebook or some other social network is by far the easiest way, I just need to be able to see who you are and associate your name with the account. Please do not make me work to verify you, come with ideas or suitable suggestions if you “don’t use Facebook”. E-mail is not a suitable option.
Connect with me on the ClassicMUD Facebook Group - https://www.facebook.com/groups/ClassicMUD/
- Michael (Sysop)
The WABAC Machine BBS
wabac.ccsnet.com 99.73.141.110 version 1.1r stock
Ministry BBS
ministrybbs.com 97.95.41.101 (3 chars non pvp) (mudrev)
Hated Reality BBS
(1) hatedreality.homeunix.net 24.247.194.96 (3 chars nonpvp unique edits has alot of the mudrev lots has been fixed tweaked) sysop is southern
(2) hatedreality.homeunix.net port 33 (stock pvp test board)
Cedarvalley BBS
all realms edited sys gotos at lvl 20 dupe at lvl 50
(1) CedarValley BBS 63.230.156.110 port 2525 (1 char )nonpvp sysop is topcat
(2) CastleRock BBS 63.230.156.110 port 2424 (pvp 1 char )
Greatermud
greatermud.com 71.39.209.17 2 realms nonpvp 2 chars pvp 1 char sysop is gardner
Skullopoly Realms
(1) 52.35.88.225 HeavensPortal.com (pvp 2 chars)(pay for gjr)(stock) sysop is skully
(2) 52.33.195.197 BrainToys.org (nonpvp 2 chars)(sys gotos)(pay for gjr)(stock)
Adept BBS
adeptbbs.com 99.89.65.1 (1 free char pay for others)(pay for sys gotos nonpvp)(stock)
Bear BBS
bear.dyndns-server.com or bbs.bearfather.net 67.170.184.233
(3 realms 2 chars per realm stock start in credit class til 2 weeks get 3rd char after lvl 45)
also running brads mudrev sysop:bear
not runnin
smokeshack.hopto.org
Phoenix.Strangled.Net
ivalice.ath.cx
playmajormud.com
mommasbackdoor.ath.cx
majorsludge.dyndns.org (2 realms)(pvp realm sludges mudrev realm 2 chars per realm)
toolshed.zapto.org (1 char pvp)(stock)
hs.host.net (stock)(mud version 1.11p beta 8)(no mod9)
whitedragonbbs.dyndns.org (nonpvp mudrev 3 chars)(sys gotos)
husk.dyndns-server.com (3 chars crust mud)
Mordhaus.servebeer.com (2 realms)(2 chars)(sys map)(stock pvp and mudrev realm)
OrbBBS.zapto.org (stock pvp 5 lvls 1 account)
smash.vmspot.com (stock pvp 3 chars no sys gotos)
mudworld.hopto.org (1 char pvp at 100 stock)
sanitysend.com (stock)
crazymud.servegame.com (2 realms)(boinkmachine pvp and nonpvp unique edits)(3 bbs accounts nonpvp 2 pvp)
darktowerbbs.zapto.org (2 realms 1 stock other edited 3 chars exp 10x no lims)
realmsofpwnage.com (2 realms 1 stock other edited 2x exp 2 chars per realm)
diminishingminds.dyndns.org (1 char some edits no scripting) sysop xeeg
seabreezegn.com (stock)
csbbs2.omega-networks.net(realm 2 5x exp lair mob ob fort mod crystaline coffer md erie pond mod spell mod witchax mod double quest exp)(3 chars)
draggonlance.dyndns.org (1 char free pay for extras nonpvp)(unique edits) sysop is koko
JUICEMONKEYBBS.COM (2 realms)(edited 2x exp no lims 3 chars)(stock realm 2 account)sysop: casey taylor
http://www.pacific-it.com (nonpvp minor tweaks such as +50 to stats some lims upped to 3, 5 accounts)
ignition-bbs.us (pvp 8 levels death -35)(lair mod 2x quest exp sys map)2-7-2014 sysop:charles christena
epicmud.no-ip.biz (mudrev pvp set at 12, accounts sysop said don't care)
digiworld bbs bbs.dijikul.com (5x exp 2x quest exp lair mod no lims)
mudbox.no-ip.biz (1 realm sys goto's sys map 4x exp more edits on the way)(no lims)
Mudhole BBS mudhole.strangled.net
Vandelay BBS vandelayreloaded.hopto.org (pvp 100 train to 100 no edits)sysop is ernak mccracken
Midgar BBS midgarbbs.no-io.org (1 account per ip 2nd char after 30 days pvp=5 stock realm) 10-4-2014
Chaos BBS chaosbbs.dnsdynamic.com (2 accounts per ip lair mod double quest mod spellcasters mod no lims pvp diff 10)sysop is spider
houseofmud.mudbbs.com (2 chars semi edited 2x quest exp cp points raised by 15 sys map and gotos gjr free at general store)
Void BBS (checked 11-4) 2 chars bbs.kyau.net (stock pvp=5 lvls 2 chars) sysop is kyau
Slime BBS (checked 12-29) 8 chars slimebbs.com (siliconrev 2 chars gotos and map pvp 50 levels) 11-1-2014
Transeo Crepusculum BBS transcrep.no-ip.biz ([2 realms] edited 2x exp, no lims pvp, stock pvp, 2 accounts each realm)sysop is shana barlow
Xtreme BBS xtremebbs.dnsdojo.net (2x lims 10 pvp dp pile raiding allowed) sysop serf 21 chars
Castle HQ BBS west.castlehqbbs.us (realm 1 mudrev 2 accounts)(realm 2 stock 2 accounts)
Evermud BBS evermud.zapto.org (stock 4 chars sys gotos at lvl 40) sysop is tycho
Kaotik Haven 68.107.116.103 2 accounts no mods pvp 2 new races 1 new class
reactivemud reactivemud.servegame.org 3-4 accounts 4x exp
Mmud BBS mmud.us (realm 1 2 chars) (realm 2 1 char)
BCG BBS webmail.bcgonsite.com port 24 non-pvp 3 accounts sys map and goto Sysop: Shaniqua
Infinitespace BBS infinitespace.hopto.org or 71.47.143.194 (nonpvp 3 chars no lims 2x exp liar mod train to 300)(sys gotos stats edited)
Blue-edits BBS Blue-edits.ddns.net siliconrev (3 chars per ip 4th with donation) ther edits sys goto's
Suckapunch BBS spbbs.gameserve.com pvp no rules 1 account lightly edited
Beebs BBS beebbs.dynamic-dns.net 3 realms stock edited mudrev 4 chars per realm reopened 3-9-2015
Xilo BBS mud.xilogaming.com mudrev 3 chars
Grimoire BBS grimoirebbs.sytes.net (stock pvp 2 accounts) website for rules and info http://www.grimoirebbs.com/bbs
OG BBS og.servebbs.com (nonpvp lightly modded 2 accounts no lims sys goto)
BadAss BBS badass.dynu.com (stock realm and mudrev pvp 100 levels sys goto and map dupes but not stated how many) 10-22-2014
Quicksilver BBS quicksilverbbs.com mudrev dunno number of accounts allowed no sys goto's
Southern Harmony BBS bbs.southernharmony.net (nonpvp stock)
PhaseShift 9-26-2015 phased.dalnet.ca 2 realms pvp and pve 2x exp sys gotos in pve 3 chars
TheJungle BBS junglebbs.com (stock death -100)
MinorMud BBS: entconn2.com port 2020 no limited items, 3 chars allowed Mods added
Carnage BBS: entconn2.com port 2323 PVP 3 chars allowed, Mods added, Max stats have been increased
Starbase21 BBS bbs.starbase21.net stock pvp? accounts??? ((mud offline do to errors))
Shadow of Darkness BBS Shadowdarkness.servegame.com PORT 2929 mudrev 3 chars per ip
Mudserv BBS conquer.themud.org port 7777 3 chars stock pvp no lims sys map pvp 15
Esoteric BBS esoteric-edits.ddns.net 67.173.127.54 (mudrev 3 chars) sysop:brad waters [badboy]
fat-yoda BBS 75.143.100.255 (stock pvp)(2 chars)
Holodeck BBS holodeckbbs.com (2 realms)(stock pvp)(2nd slightly edited)
PureMUD BBS
PureMUD BBS: 173.175.191.22 (puremud.crabdance.com)
MME DATs on PureMUD Facebook Page and on MuDINFO.net as attachments
Realm 1 Stock-based PvE - PORT: 6969
MODs: crystal coffers, deep caverns, ancient fortress, obsidian fortress, RETRO and Lair MOD, small quest fix, various minor fixes
Junkyard shops can resell what it buys and REGEN items very slowly
Quest EXP x2 and Boss EXP x2, Boss drops 100%, all items loyal
Unlimited items, SYS MAP and GOTO, and GJR - Free in Silvermere Jewelry
All trainers 1-150, Stats +100
Death: -1000
Number of accounts allowed Online: 6 per IP
Realm 2 Stock - PvP - PORT: 7777
MODs: Lair MOD, small quest fix, various minor fixes, Junkyard shops can resell what it buys
Stats +25, Boss drops 100%, all items loyal
SYS MAP, Unlimited Items, PvP level difference (100)
Death: -100
Number of Accounts allowed Online: 3 per IP
Realm 3 Standard MUDREV-based PvE - PORT: 9999
MODs: Raised Max Stats , Class and Race EXP changes, small quest fix
Fixes to bugs, glitches, and exploits, Fixed Broken Quests
Stats +100, Boss Drops 100%
SYS MAP and GOTO, Trainers up to 500
Death: -10000
Number of accounts allowed Online: 3 per IP
Mudders Inc. muddersinc.doomdns.com 172.86.120.109...pvp 2 chars per ip pvp level 10 death 35
TDR BBS tdrbbs.ddns.net 96.90.44.217 Reopened with a stock/Edited/mudrev realms 4 chars per ip PVP 7 levels
CyberSpace BBS csbbs.omega-networks.net 54.200.66.111 (stock nonpvp 3 chars)sysop:brandon bianchi
Eclipse BBS 99.89.65.2 (pvp)(stock)
Demonsnet BBS Demonsnet.com 163.172.115.48 majormud 1,1r and 11.1p lots of other games and door games
Catsweat BBS 52.87.104.178 (3 chars)(sys gotos)(non-pvp)(no lims)
Killer BBS killerbbs.servebbs.net 2 Char per IP 2 x Limiteds PVP Level limit - 10 Levels
funk soul brothers bbs funksoulbrothers.ddns.net Lair Mod and Spell Mod PVP currently set to 7 levels Death is set to -30 3 chars per ip
Retro RedMud Castle BBS mud.redmudcastlebbs.us 2 chars per ip no mods not sure if that means 1-9 or what
Entconn BBS 50.198.182.77 entconn2.com (nonpvp 4x exp 3 chars sys gotos and map)(no lims) sysop is prime
Haxxord BBS bbs.haxxord.com (port 23 or 2323) Stock, all Mods and Fixes 3 Characters max Death -100 PVP Level 5
The Nexus BBS bbs.thenexusbbs.com 174.0.73.46 (2 chars per ip pvp level 5 stock realm)
Darkside BBS darkside.dtdns.net 173.88.132.23 (stock)(pay)not sure if its still a pay board
Dustyn BBS
dragonslayer.ddns.net base realm spells mod, lair mod, unlimited items,. 5x exp no mention of amount of chars allowed
upgraded quest items and a couple items to balance for edits
Joker
Re: my bbs list
Post by Joker » Sun Apr 02, 2017 8:38 pm
Thanks again for keeping this going!
Re: my bbs list (updated 7-26-2017)
Post by Bloodrock » Wed Jul 26, 2017 11:07 am
update 7-26-17
Sodium
Post by Sodium » Fri Apr 13, 2018 9:08 am
update 7-26-17
Both pimptite and themajorbbs are down. Pimptite for roughly 2 months, themajorbbs for 3 days.
