lostways reopens
lostways bbs reset
for the first time in over 15 years lostways bbs majormud will be reset would like to see all that are on and any new players. lots of new gear areas bosses and quests have been added to game in the past 3-4 years. the system very very rarely crashes. i am a very attentive sysop checking on things all the time thou i may not say anything i do check. always open to suggestions. the new areas added i have in most cases if on a default megamud path have used go path or go crack this in return helps not to mess up megamud default paths. signs in room b4 bishop and in bishops room list new bosses and new quests. the reset opening date will be june 1st. there is also a mme zip file which includes paths and loops for new areas. and several other files for the bbs edits and etc.. link for mme zip file https://dl.dropboxusercontent.com/u/306 ... aysbbs.zip
llostways bbs reset
getting close to june 1st lostways bbs reset so time to set rules for each realm....... edited realm as many chars as you want.... has sys goto and sys map..... top level lowered to 400 from 500.... no limited items.... thesysop is the mudbot bot commands can be found in a sign in hod...... level 10 questors sold in junkyard if needed... but since there is a new quest using spirit best to go to level down in crypt.... a sign in room b4 bishop lists new bosses.. a sign in bishops room lists new quests.... ..... pvp realm 2 chars per person.... no sys goto or map... no mudbot....is a stock realm...... will be a sysop account in game but will not play... do not ask sysop for anything cuz nothing will be done... date of reset is june 1st 8am central time
Re: llostways bbs reset
added a non pvp stock realm 3 chars per person free gjr's in general store in silvermere will create a modbot
yes there are files in the mme zip file and in game is a sign in bishops room for new quests room b4 bishops room is a sign with list of new bosses is a sign in hod with list of bot commands
link for mme is https://dl.dropboxusercontent.com/u/306 ... aysbbs.zip mme has been updated for any new additions and or changes
lostways reopens
lostways bbs reopens in 2 hours
edited realm 6 chars allowed get sys goto's and map no limited items gjr's sold in general store mudbot new quests many new area's
non pvp stock realm 3 chars allowed lair mod installed no limited items gjr's sold in general store sys goto's and map mudbot
pvp realm 2 chars allowed lair mod installed
