Author: Syntax (AIM: syntx53, Email: syntax53 at mudinfo.net)
Created: 6/4/2004
Base Mud Version: v1.11o
Description--
Adds lairs to to many of the built-in scripting areas. This makes all of the scripting areas handle more people per area and in some cases makes areas that weren't worth scripting now worth it. Contains an undo database as well. It would be wise to import this mod with the "Not Items" setting turned on so you don't erase users items on the ground.
Details in attached pdf
Lair Mod
Lair Mod
- Attachments
- Lair_Mod_v1.2.zip
- (1.82 MiB) Downloaded 678 times
- Lair Mod v1.pdf
- (401.45 KiB) Downloaded 1042 times
