create a spell that acts like sys e 1 1
Posted: Sun Dec 29, 2019 12:52 am
by EripGalava
is it possible to create a spell that acts similar to sys e [rm] [mp] command
basically id like to have a spell handy to allows me to teleport anyone on command to a given area?
if so how would i go about this
Re: create a spell that acts like sys e 1 1
Posted: Mon Dec 30, 2019 11:20 pm
by Ravyn
Yes its quite easy create a general spell set it to cast on self/user (or whole party whatever you wish), magery type none unless you want it to go with a class, set the damage range to the room range. So, damage range 1 to 1 would land them in room 1, damage 1 to 10 would land them in a random room between 1 and 10 (this is seen in the lich scatter spell from Dark Mage), then the abilities screen you use TeleportMap (#), and TeleportRoom 0. Or you could leave the damage blank and just put in the fixed room # you want.
You add the casting messages to be whatever you want them to be, usually just something like You disappear in a flash of light! and %s disappears in a flash of light, or whatever you want...
Posted: Mon Dec 30, 2019 11:22 pm
by Ravyn
Although you cannot specify the room and map #'s while casting if thats what you meant, itll teleport to a random or fixed room (like using sys jail)
