Removing Good/Neutral/Evil only flags in NMR?
Posted: Thu Jul 12, 2018 5:35 pm
by Necrosaro420
Is there a way to remove the alignment requirements for items in NMR instead of doing each one individually? Unless I missed it, did not see that option anywhere?
Re: Removing Good/Neutral/Evil only flags in NMR?
Posted: Thu Jul 12, 2018 8:08 pm
Necrosaro420 wrote: Thu Jul 12, 2018 5:35 pm Is there a way to remove the alignment requirements for items in NMR instead of doing each one individually? Unless I missed it, did not see that option anywhere?
I don't have NMR installed on anything right now, but can't that be done through the mass change tool?
Posted: Thu Jul 12, 2018 11:15 pm
by Ravyn
I don't believe so. I have it pulled up and closest thing is "universal modifier" then choose "items" then "change ability" then you can change the value by adding, subtracting, setting value, dividing etc. since the ability works with any value (NeutralOnly 0 is same as Neutralonly 100) i don't think itll work. exceptions may be changing EvilOnly from a higher value to 0, so you can use it as a lesser evil person?
Posted: Thu Jul 12, 2018 11:16 pm
remove ability isn't an option??
Posted: Fri Jul 13, 2018 1:19 am
by Necrosaro420
Nope, not seeing remove ability in the universal modifier section.
Posted: Sun Jul 15, 2018 7:30 pm
i'd think use change ability would do what you want choose the abil and modifier would be = 0 would prob have to do it for each alignment
