Setting up a new board
Re: Setting up a new board
Yes the mud codes are based off the bbs codes. So will need to reg WG first then can generate mud codes.
MiOw
Post by MiOw »
Yes, a bad reg code for MMUD in the BBS settings, security and account if I remember right(?), will present the issue your experiencing. As for the WG code, I forget it’s limitations, but I always prefer entering it during install.
Once you have a working set I suggest saving them all in a .txt file. This makes re-installing a breeze, though now I just re-use my baseline .zip file of my WG folder.
synacktic
Post by synacktic »
I've been testing with WG2 (DOS) and I got a license violation error, what needs to be replaced / changed to fix that? Like which files does it keep track of that being an issue?
