wccupda2 FILE & Can't Update file
Julian
Post by Julian » Thu Dec 13, 2018 11:42 pm
Why is it no longer possible to compile an update file?
Nightmare gives me an error.
I am running pSQL db engine as my Btrieve db engine.
I can't compile a blank update file either?
I am running Nightmare Version 1.6.1.
Please help & Thanks!
Julian
ps My problem is if I do a real time update, such as adding an item to a room, it doesn't appear until after cleanup.
Re: wccupda2 FILE & Can't Update file
Post by BearFather » Fri Dec 14, 2018 10:01 am
The update file is only picked up at cleanup, or if you run the util in the mud sysop menu. Also the error you get would come in handy to help with the issue.
Julian
Post by Julian » Fri Dec 28, 2018 10:19 am
Ok, so I run Nightmare 1.8.1 and the previous version until I upgraded.
I go to TOOLS -> Compile update file..
I receive a popup in NMR:
ERROR CREATING UPDATE FILE: Invalid Location (11)
GO TO FILE --> SETTINGS AND SET YOUR DEFAULT DAT FILE PATH AND CALL LETTERS.
Shows:
Directory: c:\wgserv
v1.11p
cc
bottom
nothing else is checked.
I'm running psql btrieve.
Post by Bloodrock » Sun Dec 30, 2018 9:05 am
did you read my reply on your other post on this issue??????
Post by Bloodrock » Sun Dec 30, 2018 9:09 am
i think the psql may be part of the issue not sure since i don't use it either the psql is locking the files or has moved the files really have no idea other than the files are being blocked why not try setting up a vm or on a different comp wg and mud without the psql????
Post by BearFather » Sun Dec 30, 2018 1:44 pm
Did you apply the patch to nightmare for psql?
Julian
Post by Julian » Fri Jan 04, 2019 9:59 am
Yes.
I copied the btrv32 into the nightmare directory and the wgserv directory. Tried installing to a new WGSERV directory, while making the other one WGSERV-ORIG;
Wouldn't work whether the BBS was up or not.
I ended up making a new VM (virtual machine.)
That worked. Rebuilt the DAT files and is all good now. I have an original, blank, WCCSUPDA2.dat file.
Good Luck!
Julian
