Hi!
Something is wrong with my system goto..
I type:
sys goto
the response is:
command not recognized.
Sysop has the master key, right? same error.
I have the ini file as mentioned in other parts of this board. Everything is the same.
The CNF options for gameop and sysop are left blank.
any ideas?
sys goto command not recognized
Re: sys goto command not recognized
Change the cnf options to "NORMAL" do you get them back? The normal key all users get btw.
make sure that the keys in ini file are same as what you set in the mmud settings if in settings key is sysop and gameop ini has to be that too.
if set to normal ini has to match.
