Problem with MajorMud on Entertainment Edition
The preconfigured entertainment edition on major.butt.care has majormud version 1.11r and all 9 keys for the addons already installed in the sysop menu. I have it running just fine on Virtual Box and VM Player but unfortanetly the Addons don't appear to be unlocked no matter what I do. Sys go sup gives no exits. I tried restarting the BBS and it doesn't change anything. Can anyone give me a hand?
Re: Problem with MajorMud on Entertainment Edition
why use that when you can get the package worldgroup 3.30 with mud 1.11p and fu globals and dialsoft control and keygens for it all from same site
I bet the keys are actually not installed. If you login and goto the sysop mud menu and hit "a" it should list out 9 keys for you. If it doesn't then no keys are installed. If it is I doubt they work since they are based off your BBS code which is per install.
All 9 are listed there I wish that was the problem. When I use the keygen I get the same keys listed in the addon menu. Is it possible MajorBBS has different keys than Worldgroup and they keys I have are wrong? Or maybe if I delete the keys manually from the key file and then input them manually all over again?BearFather wrote:I bet the keys are actually not installed. If you login and goto the sysop mud menu and hit "a" it should list out 9 keys for you. If it doesn't then no keys are installed. If it is I doubt they work since they are based off your BBS code which is per install.
As long as I dont have to install everything from scratch I am all for it. I am using Windows 10 so I found using perconfigured VMs with a BBS already preconfigured is the easiest way to go. Where is that link on that website so I can check it out though? Major butt care for me has only one page I can access.Bloodrock wrote:why use that when you can get the package worldgroup 3.30 with mud 1.11p and fu globals and dialsoft control and keygens for it all from same site
wg mmud code will not work in mbbs (majorbbs) need to find a keygen for mbbs or try one of the mbbsforever zips heres my link to major butt care === ftp://major.butt.care/mirrors/BBS/
UNofrtunately the mbbsforever codes are the same as mine and if what you say is true then they are the wrong codes because the WG keygen gives these same codes and this is MajorBBS. Every build for MajorBBS on the main page of major.butt.care has the wrong addon codes then. I guess I will have to try to find a MajorBBS keygen. I'll let you know if I do.Bloodrock wrote:wg mmud code will not work in mbbs (majorbbs) need to find a keygen for mbbs or try one of the mbbsforever zips heres my link to major butt care === ftp://major.butt.care/mirrors/BBS/
EDIT: I Got worldgroup with MajorMUD 1.1p running and have the modules installed correctly now. Thank for trying guys I appreciate it. I didn't realize MajorBBS and Worldgroup keys were different.
