Scripting Programs
Re: Scripting Programs
Post by BearFather » Fri Nov 02, 2018 9:55 am
Have you made up a set of mess and resp for this new poison? Might do that and check "poison" so mega knows it's a poison. It might also be the kang part, where mega might auto ignore poison cause he's a kang? Really just a stab in the dark.
Gridlocked
Post by Gridlocked » Fri Nov 02, 2018 1:33 pm
I am just going to have to ignore the poison. No one can figure out if there is a @poison command, and the message/reply isn's working (I cant get the priest to cast cure with straight triggers I set up personally.
Like I said earlier. This would'nt be difficult if there was a simple easy IF/THEN set up. But since this program is so old, doubt that will happen :)
I just walked into the Pastors office found my curi spell. What I will do is a pre rest command where the priest will just cast curi before resting. That should cure evryone in the party
Gridlocked
Post by Gridlocked » Fri Nov 02, 2018 2:00 pm
I give up.
I thought the curi spell cast a cure poison for the group. Not curing anything at all. Just blew threw 700 mana chain casting curi because it wont clear poison...
Post by BearFather » Fri Nov 02, 2018 10:42 pm
My memory is hazy but isn't it merciful grace?
ohno
Post by ohno » Wed Mar 06, 2019 2:07 am
BearFather wrote:
Thu Oct 18, 2018 9:58 am
Edit:
C:\Users\<user>\AppData\Local\VirtualStore\Windows\MegaMud.INI
change AutoLoadIni=1 to AutoLoadIni=0
Check the Directory= a valid place
\\HKEY_CURRENT_USER\Software\GWiz\MegaMud\Directory make sure that matches up.
I am having the same problems. Numerous times I have followed these instructions, but I have not had luck.
I do not have - C:\Users\<user>\AppData\Local\VirtualStore\Windows\MegaMud.INI on my hard drive. Recommendations or suggestions?
Also, this problem began for me when I attempted to save as under a new folder for a second character. I was having troubles with the auto loop / roamer confusing settings between a mage and paladin while grouped.
I don't wan to give up on this game, but I question how feasible this is. I have spent a lot of time trying to correct this issue.
Post by syntax » Wed Mar 06, 2019 8:15 am
From: http://www.mudinfo.net/viewtopic.php?f=4&t=2059
Have you checked in "C:\Users\YOURPROFILENAME\AppData\Local\VirtualStore\Program Files (x86)\Megamud" and/or the regular directory of "C:\Program Files (x86)\Megamud" ?
ohno
Post by ohno » Wed Mar 06, 2019 11:09 am
Thank you for the link.
I followed the instructions. Now I am receiving a new error code of - Cannot find file MEGARES.DLL
ohno
Post by ohno » Wed Mar 06, 2019 2:40 pm
Gridlocked wrote:
Thu Oct 18, 2018 9:00 am
https://www.facebook.com/photo.php?fbid ... =3&theater
Link shows it is installed.. with no way to uninstall per your instructions (I just go right to the control panel and search)
Mine is not showing it as installed . . . . Little help pls?
ohno
Post by ohno » Wed Mar 06, 2019 3:33 pm
Thank you for your time.
I just figured it out.
ohno
