High Druid Quest
High Druid Quest
From MMB:
  1. Find the clearing off the forest path (the one a little bit SE of the blue tower where a dark druid often sits). TWIST KNOT, PUSH KNOT to open the secret passage into the tree.
  2. Kill a few dark druids until one of them drops a darkwood ring.
  3. This ring will allow you to pass through the shimmering arch into the center of the tree. Dont bother to spell up before you "go arch", because all of your spells will be removed upon entering the high druid room.
  4. When you have gone past the arch as far as you can, GO ARCH will pop you into the room with the High Druid and several Dark Druids.
  5. Type TOUCH GEM once everything is dead in that room.
    You will get +1 to SpellCasting
From MudVille:
  1. Gather one darkwood ring for each member of the party
  2. Enter the lair of the High Druid by going through one of the 4 archways
  3. Kill the High Druid and all his buddies
  4. Touch the Gem
    Your reward is +1 Spellcasting
From MudCentral:
  • Find the clearing off the forest path (the one a little bit SE of the blue tower where a dark druid often sits). TWIST KNOT, PUSH KNOT to open the secret passage into the tree. You will have to kill a few dark druids until one of them drops a darkwood ring. This ring will allow you to pass through the shimmering arch into the center of the tree. Dont bother to spell up before you "go arch", because all of your spells will be removed upon entering the high druid room. When you have gone past the arch as far as you can, GO ARCH will pop you into the room with the High Druid and several Dark Druids. Be prepared to be heavily damaged!
